Hi guys,
I've just bought a Gigabyte P35 DS4, separate to the 24pin psu connector, there is an 8pin power connector that has a cover over 4 of the pins. The manual isn't very clear what this does and if i need to use all the 8pins or not. I've got a Corsair 620w psu, which has both 8pin and 4pin connectors, i just need to know which one to use.
The system is running a 8800 GTX overclocked an a Q6600 which I plan to overclock aswell.
Cheers,
LJ
p.s. I would searched the forum for the answer, but I can't find the search link, where has that gone? or am I just blind now :-/
Cheers,
LJ
