A little maths help please
27 Oct 2002
Could some kind soul please tell me how to solve this for x. It's been a long time since I did a-level maths, and can't recall if or how I ever did this kind of thing!
254 = 255x - x^12
calnen said:
That confused me as well :confused: If it's 'x to the power of 12' then it becomes rather more complicated.
yer i didnt misread it but just didnt look long enough, and im still in as level so i went by what i knew which is what i sed lol :p
doh. it is not a quadratic.
Basically I'm starting a fictional .com business earning £1000 in the first month with a total of £255,000 earnt by the end of month 12. How much would I have to make each month asuming the growth in linear?
I got this far
a + ar + ar^2 + ar^3.... ar^11= Sum
a = 1
Sum = 255
r = ?
n = 12
If you think of it as a straight line graph would that help?
(I mean that if you plot (1,1000) and then (12,255000)).
So the gradient is:
Change in Y / Change in X
(255000 - 1000) / (12 - 1)
254000 / 11
23090.909090909090909090909090909
Therefore the equation of the linear growth would be:
y = 23090.909090909090909090909090909x + c
Where "c" is the Y intercept.
Therefore:
x = 1, y = 1000
1 * 23090.909090909090909090909090909 + c = 1000
c = -22090.909090909090909090909090909
So the equation is:
y = 23090.909090909090909090909090909x -22090.909090909090909090909090909
Then plug in the numbers: 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 for "x" to get the monthly figures.
Would that work? (I am not thinking terribly deeply here).
Angus Higgins
First thing that strikes me is that x=1 is an obvious solution.
Second thing that strikes me is that if you differentiate it you will find that there's a unique turning point, so there can't be more than 2 solutions.
To find the second solution you can either do it numerically (it's a shade below 1.5) or you can use polynomial long division.
Angus Higgins
I'm not sure I follow. are you talking about graphing cumulative income? Because by the 12th month I want to have made 255k all together.
I got this far
a = 1
Sum = 255
r = ?
n = 12
What you've posted there isn't linear growth, it's geometric (or exponential) growth. An example of linear growth would be 1000 in month 1, 2000 in month 2, 3000 in month 3 etc.
So you're looking for the number x such that
1000 + (1000 + X) + (1000 + 2X) + ... + (1000 + 11X) = 255,000
Which simplifies to
12,000 + 66X = 255,000
254 = 255x - x^12
x(255-x^11)= 254
therefore x= 254 and
255-x^11=254 ==x^11=1 therefore we can say x=1
x=1 and x =254 unless i am flawed in my thinking, it's been a few years since i've had to deal with these.
SpeedFreak said:
254 = 255x - x^12
x(255-x^11)= 254
I think the flaw comes in the line where you start with "Assume x=254..." and end with "...and therefore x=1". ;)
Ahhh, I think mine is wrong due to that; I didn't think it was cumulative. :p
SpeedFreak said:
254 = 255x - x^12
x(255-x^11)= 254
Wouldn't it have 12 solutions being a 12th order equation?
Angus Higgins
