- 23 May 2018
external soundcard route! one of them Creative high end?
like x7
I kind of dabble in Pro audio, using an rme fireface 800!
like x7
new bios look of x570 will come to x470 after X570 has been sorted out i think . Hopefully lessons learnt will be applied to B550
After some 16gb DDR4 3600MHZ RGB Kit, Any leads @orbitalwalsh
That b die page is most outdated now on links ,stocks changes in ics.
Pay up to £150
2. Before update BIOS to F40, you have to install EC FW Update Tool (B19.0517.1 or later version) to avoid 4DIMM DDR compatibility on 3rd Gen AMD Ryzen™ CPU
Bios 41C came out yesterday, agesa 1.0.03. My clocks still look to max at 4275 in a dual core test of cinebench. Will test thoroughly tonight...
Is there any way to check and see if the EC FW Update Tool has been run?
AutoFlash=1
AutoFlash=0
What ram you running m8 and is it on XMP?All is well here despite not installing that tool,
