** A WILD S-FRAME APPEARS **
OcUK Staff
26 Nov 2014
Stoke
Now in stock, In-Win S-Frame Black/Gold. For the more subtle chassis enthusiast ;) Very limited stock available!
In-Win S Frame Midi-Tower USB 3.0 - Black / Gold @ £646.99 inc VAT
In Win has introduced its new LIMITED open-frame chassis with a unique one-piece construction design concept combining unconventional craftsmanship techniques to create an impeccable artistry.
Using laser cutting machine processing to cut 4mm thick aluminum sheet metal into a 2 meter long chassis structure the In Win S-Frame is made using complete one piece metal with CNC polishing processes. The dual anodize procedures not only increased the resistance of the aluminum surface but also features a dual colour Black & Gold presentation to give maximized visual enhancement.
Finally, the main structure of S-Frame was bent through 15 times in order to create every bending angle smooth and seamless. These processes also created a beautiful texture of brushed hairline sliding along S-Frames curves.
S-Frame’s simplistic aesthetics required a selection of delicate techniques to accomplish the uniqueness, strength and perfect artistry enjoyed as the S-Frame becomes available …
Specifications:-
- Material: 4mm Aluminum, Tempered Glass
- Internal Drive Bay 3.5” or 2.5” x 4
- M/B Form Factor ATX / Micro-ATX
- Power Supply ATX12V, PSII and EPS
- Power Supply Mounting Area Length up to 300mm / Height up to 95mm
- I/O Port USB3.0 x 4, HD Audio
- I/O Expansion Slots PCI-E Slot x 8
- Supports High-end Graphic Card
- (Length: up to 340mm, Height: up to 160mm)
- Thermal Solution Supports
- 120mm Bottom Fan x 3
- 360mm Liquid Cooling Radiator(width up to 135mm)
- CPU heatsink up to 195mm
- Dimensions (H x W x D) 560 x 313 x 755mm, 22” x 12.3” x 29.7”
- Net Weight 17.41kg
- Gross Weight 23.2kg
- Our products comply with RoHS regulations
* Specifications may vary based on different regions
Only £646.99 inc VAT.
ORDER NOW
For the obsessive-compulsive show-off with money to burn and amazing cable-management skills living in a dust-free environment with no pets or children.
Very futuristic looking, tempered glass should be standard in most cases, better than creaky wobbly perspex at least.
I love innovative designs, but In-Win are off their rocker if they think I'm spending north of 600 squids on a case!!!!
