About to start first build, few questions
lastly, for the LEDS it says some have a plus, some have a minus which corresponds to the slot, but the plug just says RESET SW or POWER SW, how do i tell the + - charge part?
cheeeeers, getting close to turning it on, fans connected, all screws in place (correctly :p) power cables connected, parts all of the mobo, HDMI cable ready, tv reacy, psu all connected, anything i should watch out for before turning it on?
Nope, I have closed the manual know!! there should to pins that you short near the battery, this will be labeled CLR CMOS or similar.
Double check all power connections including the 8 pin for cpu power & gpu.
Does the board have any light on.
Can take a quick photo on the board and post up.
