Hi,
My ABS Warning light has decided to rear it's head this week. I am assuming the most likely culprit is a failed sensor, if there any easy way to check which one it might be without buying a new one to fault find?
I am hoping it might just be one is bunged up with debris, or knocked out of alignment.
On top of the rust which has reared it's head in the usual places, a rear caliper that seems to have become lazy, and needing about £300-£400 of new tyres! I could have done without this!
Maybe I shouldn't have bought the new seats, they are rather tasty red alcantara though.
Any hints on this one are much appreciated.
Thanks
Thanks
