Hi,
I'm not sure why you'd want to replace the stock fan on an Arctic Freezer 64, especially with another Arctic Cooling 92mm fan...
Anyway, I don't think you can change the fan on a Freezer 64, although with a little pushing + pulling you may be able to swap the two fans by removing the rubber dampers from the plastic mount.
I'm guessing the fan has broken on your Arctic Freezer 64?
Banjo
