** Acme [Akagi] bought a pink estate car - E30 325i project log! **
26 Feb 2007
Have you looked into one of the FM jobbies that goes in-line with the antenna instead of broadcasting it's own signal? They're £40 or £100 depending if you want bluetooth or not and are supposed to be much better than the FM trans type.
Caporegime
OP
29 Jul 2011
In acme's chair.
Dropping the subframe is the easiest way to do it in a shop, but there are alternative fiddly methods involving undoing the oil pump bolts through a tiny gap and having it fall into the sump pan and then wiggling it out of a tight gap which you can do if you so choose!
I did request that they use Loctite or something and not a cork gasket. :)
But yeah it really is that fiddly to do the sump gasket... I was surprised too... I was expecting to just drain the oil, undo the bolts around the sump, pop it off, clean it up, and bolt it back on with a new gasket... Nope!
Caporegime
OP
29 Jul 2011
In acme's chair.
Yeah yeah, I should have done this stuff myself. But 'ehh... :p
There will be pics upon its return. And I have some stuff I need to do to it myself once it is back, never fear! :)
Bonnet to fit, valance to paint, foglights to fit and fix, speakers to fit and wire up, head unit, surface rust on panels to whizz back then pickle, prime, and paint, door cards, headliner to strip and re-trim, sunroof seal, door seals, rear aerial to remove, various interior trim things to fiddle with and fix, the paintwork to buff, one outer rear arch to attempt to sand and rattle can to improve on the lacquer peel, etc.
The only things I plan to get other people to do are the rot repairs, and making my new exhaust. I only planned to get the garage to do the sump gasket, but I decided to just get a load of stuff out of the way by getting them to do it at the same time. :)
Man of Honour
17 Oct 2002
Ottakring, Vienna.
It's an inline mounted engine, by design it's pretty likely there will be something significant underneath it blocking access to the sump.... pretty different to most transverse FWD set ups.
Caporegime
OP
29 Jul 2011
In acme's chair.
So I don't even have the car back yet, but I just spent £200 on a complete OEM optional OBC kit. Bought from a New York bus driver! :p
Its the fully fledged 13 button version with the light bar. Does all kinds of stuff! Coded immobiliser (like a pin code to start the car, how 80's cool is that?!?! it also sets an alarm off if you enter the wrong code three times!!), MPG average, speed average, range, remaining fuel in litres, programmable maximum speed warning, time and date, exterior temperature, and even a stopwatch! It also sounds a chime when the exterior temperature is below 3 degrees C, sounds another once it goes above 6 degrees, and you can control it from the indicator stalk as well.
I'm really excited about this bit. :D
