Right then, update time. Sprayed the black section of the rear valance because it was all patchy:
Before/after example:
Did some mopping on the other side. The DA polisher was being a bit temperamental though so I didn't do it enough, its still slightly pink. Will give it another go when its not raining:
Painted the front valance a bit better. Should have masked the tyres... Meh! It was mostly my mate who did this, sanded it down with a pad sander and primered/rattle canned. Still has some texture to it but its smooth in places because of the sanding.
My mate did the yellow high beams on his car, he isn't sure about them. Personally I think they look great on a silver one!
[pic removed]
Fixed
@Voxination's polisher. This wire was loose and the tab it connects to was corroded:
Cleaned the connection and squeezed the plug together a little so that it fits on tighter. Good as new, and works brilliantly.
Mmmmm red...
