Matt82 said:what exactly does it 'learn'?
Wolfchild said:If i recall you can do this on the E46 without disconnecting the battery.
I think! it goes like this.
Insert Key, turn to position 2 and count to 10
Turn key to off position and count to 10
Turn key and start car right away without leaving in any of the ignition positions.
Worked for me when i did it a while ago so i think the above i correct.
Its a BMW approved method by the way as its in there service manuals.
5tephen said:Same in an E60 as it worked for me a couple of weeks ago (my D mode is closer to DS now, hanging in gears a little longer) and afaik it works on the E39 too. The OP's method sounds like too much hassle![]()
R124/LA420 said:1,I'm not the OP!
2, Thats the only method I could find for an e38 - it certainly works though.![]()
