Possible to add fan to Noctua NC-U6 Dual Heatpipe Northbridge Cooler?
Hello guys
Been starting to get weird lockups on my system which I'm guessing is down to either 3 things. Not enough juice to CPU and NB, 1T command rate on my ram or overheating NB.
I have swapped out the default cooling on my P5Ne-SLi to Noctua NC-U6 Dual Heatpipe Northbridge Cooler which seems to do a helluva lot better job than the stock heatsink.
But I was thinking of adding a fan to it. Has anyone done this? What kind of fan would fit this heatsink, I see there is grooves on the heatsink which seems to suggest you can add a fan onto it with the correct retention mechanism. Where would I be able to buy one of the fan retention clips?
Sorry for so many questions, hopefully some one will have tried this before or has some ideas.
I will change the voltage and command rate when I get home from work, but I still think added cooling could help as it still gets hot and if the weather gets hot again...
Hello guys
or I might invest in some cheaper new UPS as I do like the line filtering to ensure no over volting etc.
