This is the first ADSL Max connection I've had setup, so I'm not familar with how the training process works.
I've found my sync rate can vary between 4.4Mbps and just under 6Mbps. However, on some sync's basic web surfing can be one legged pace (or just not work at all).
For instance, I've just rebooted my SpeedTouch 546 and these are the stats:
Uptime: 0 days, 0:07:16
Modulation: G.992.1 Annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,480
Data Transferred (Sent/Received) [KB/MB]: 307.00 / 1.62
Output Power (Up/Down) [dBm]: 11.5 / 17.5
Line Attenuation (Up/Down) [dB]: 26.5 / 44.0
SN Margin (Up/Down) [dB]: 17.0 / 6.5
Vendor ID (Local/Remote): TMMB / P
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 379 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 17,299
HEC Errors (Up/Down): 0 / 10,065
How do the line stats look? I suspect the previous owner of the house bodged the two extra phone extensions in (given his obvious lack of skill for DIY I've found exhibited elsewhere). I've got microfilters on all three extensions. I could get one of our comm's monkeys from work to come and improve the wiring.
I can guess the number of CRC errors is bad but what's an HEC error? Is it typical to get errors or should the counts remain low?
