Hi
First post, be kind
Just bought a load of components from OC. Put everything toghether yesterday, everything worked fine.
Today, I start the machine up, it gets as far as loading windows, then shutsdown. I removed the connectors from the SATA drives I have, went into the BIOS diag, wait 5 secs and the machine shuts down within 10 secs.
I get no error message. I leave the machine 1/2 hour to see if it's an overheating problem (all the fans are working fine) and the same issue re-occurs, hence I don't think it's a heat problem as it happens very quickly.
I'm a bit confused...
Bits bought were:
HSI X1900XT
Conroe 6600
Asus P5B Delux (which I had to flash as it gave an error about the Conroe - uCore issue or something)
2X1Gig Cosair 6400C
2Xseagate barracuda 250G
I'm suspecting the CPU is goosed? I don't really want to return the whole lot to OC, but there's a problem somewhere which I suspect is the CPU but I can't test thing given the damn thing won't boot!!!
Regards,
crude
First post, be kind
Bits bought were:
HSI X1900XT
Conroe 6600
2X1Gig Cosair 6400C
Regards,
crude
