Advice on buying triple monitor or 3D
11 May 2010
Looking to buy monitor soon since i have been using the 40" for while but couldn't stand using that big screen up close. Mainly use for gaming and opening many browsers when surfing but a lot people mentioning 3D monitor so are their any pro and con for both type?
I have ATI 5970 is that compatible with 3D, my budget probably £400-600
Because your with ATI your limited with 3d. But your not limited to how many monitors you can have
I recommend
http://www.overclockers.co.uk/showproduct.php?prodid=MO-067-IY&groupid=17&catid=510&subcat=
3 of them if you have the money.
If you want the biggest 3 monitor eye infinity setup get 3 of
http://www.overclockers.co.uk/showproduct.php?prodid=MO-065-IY&groupid=17&catid=1120&subcat=
But its slightly over budget by £100?
if you sell your 5970 and get a SLI 460gtx setup, you will have enough money left over for a 3d surround setup. Which i do recommed. Its 3 monitor setup with 3d ;)
Both are good
Triple screen 3d is amazing but very expensive for a quality experience on PC using nVidia e.g. SLI...
Try one 24" 3D monitor first
3D surround you want GTX 480 SLI as a minimum from the little i've managed to gather about such a setup.
it needs SO many pixels to be pushed.
I recommend
Thank I would like to try out what 3D is like though don't know or how much the 5970 can sell for since I got this July, will have a look on those link you provided
