Advice on PC Build for son (1st build)
17 Jan 2021
I'm helping my son to build a PC for his school work/gaming but am a complete novice at all this and would greatly appreciate some pointers if possible.
I have gathered together a list of parts as follows. I am definitely trying to keep costs down where possible:
Motherboard - ASRock B550 Phantom Gaming 4, AMD B550
CPU - AMD Ryzen 5 3600
GPU - MSI Radeon RX 5600 XT Mech OC 6GB
SSD - 1TB Crucial P1 M.2
SSD - 1TB WD Blue SN550
RAM - Vengenance Pro 16GB (2 X 8GB) Corsair DDR4
RAM - Vengenance Pro 16GB (2x8GB) Corsair DDR4 (3200)
Power supply - 650W Corsair CV Series 80PLUS Bronze
Power supply - 650W Seasonic Core Gold GM-650 80PLUS Gold
Case - NZXT H510 Mid Tower Chassis
Extra fans - 120mm Corsair iCUE SP120 RGB PRO, 9 Blade, 8 LED Addressable, Triple Fan Pack
But I am a little confused about what else I need and have some questions as follows, if anybody would be so kind to offer their expertise:
1. Would the above function as a gaming machine / be able to handle graphically demanding AAA stuff?
2. Will the stock CPU cooler (Wraith Stealth) be sufficient? I don't know what overclocking is, but should my son attempt this at any point, will the system be able to handle it?!
3. What other fans will I need? My son wants some RGB fans ideally so would I need 2 or 3 Case fans to keep things cool?
4. Does the RGB stuff (fans / RAM) just automatically light up when plugged into the motherboard, or do I need any other components / software to achieve this?
5.To get Wifi into the machine, do I just need to but a separate card for the motherboard and does this need some sort of antenna (which would need to be bought separately too)?
I appreciate it's a lot of questions - Thanks so much in advance for any tips on the above!
Best,
Ben
23 Mar 2011
West Side
Hi,
Rgb memory should work plugged straight in case fans some have built in controler and some can also be connected to the motherboard .
You should aim for 3200mhz ram its optimal speed for the 3600. The cooler on the 3600 is adequate but can be noisy .
5600xt is good for gaming depending on resoloution.
Wifi you can get a pcie wifi card this will have an antenna or a usb Wi-Fi. Motherboard maybe you could changec to one with built in wifi.
Psu is low end budget model spending a bit more on a quality unit would be my advice.
Rgb cases
My basket at Overclockers UK:
Total: £275.02 (includes shipping: £25.14)
OP
17 Jan 2021
Hi,
Mickyflinn - thanks so much for the info. The memory info is particularly useful but some other good points too.
Underboss
9 Nov 2005
manchester,uk
OP
17 Jan 2021
Thanks for this Lee32uk.
That's great to know an alternative power supply. Is 650W the minimum I need or could I go lower for my build?
Also, is that Wireless USB adapter everything I need for Wifi, or would I need to purchase a separate card? Would the signal be strong enough?
Cheers for the help,
Ben
Underboss
9 Nov 2005
manchester,uk
Ben
I would stick with 650W as it will allow for future cpu/gpu upgrades.
That adapter is all you would need. Honestly no idea how good it will be as wifi can be a bit hit and miss depending on how far the router is etc. If you wanted an alternative to wifi then you could look at powerline adapters.
The one below is an example. If you are shopping around you can probably find a cheaper alternative. I would stick with brands such as TP-Link, Devolo or Belkin etc. You should be able to find a basic kit for around £25 - £30 if you don't need one with an A/C passthrough.
Total: £48.65 (includes shipping: £8.70)
17 Jul 2010
EsaT - thanks for the info about the RAM. Mickyflinn also pointed that out and meant to change it in the OP.
This is the RAM I'm now going for. Would this be OK?:
Total: £137.69 (includes shipping: £8.70)
[/INDENT
And will check your recommendation on SSD too - cheers for that.​
Yes, but available cheaper elsewhere. And not by a couple of quid either.
OP
17 Jan 2021
Thanks for the heads up.
Apart from some extra fans, this is what I have at the moment.
Cheers to all for the help so far.
Just need to be patient waiting for the graphics card (had no idea these were currently so hard to get):
Total: £964.15 (includes shipping: £12.30)
OP
17 Jan 2021
You've all been v helpful so far, thank you.
I have one more query before purchasing the build.
I'm having trouble sourcing the original Graphics card so have switched it to the following, which hopefully will be arriving at the end of March:
GPU - PNY NVIDIA GeForce RTX 2060 6GB Dual Fan Turing Graphics Card
ni6GCBFy-UJimn0Dt_u4XjJfvNVkXhBU-N9iruvuTIirLxwVpAHwh-batCxfdpv4zZ31puo98UVbMOqmU4JY1Cry5pjRInUormdCrnGsopGAYydTgcT8LYbgaZ-qBqJgCw1WDotl5y9Mh4XaWq0HsLDNdkU8OeEzqrMr-TN7CJRmeA-6vkj5ChFPUAdb4iUAvqptPmYP3Jb9oECP4LBJy7vMF0WwLV6kjf8K776hQbq9s6sf8huAzKyORHJQiTZSKRH-vMrF188MNJ9wt1DcgpFRyhDjDL5Hfj48FkA7zZPFDXZXGqCI3f2fz1xc2IP8hrWJ-Q0CyrSFDr_ZEnYoVRXsFupkFzlTdUrNfJOH-usLrr_naTEbjGPRVCgMQQmaCbi56JxOAhg_EabnEhXgdTFJQyabCfoxs1LlHpYzWPMqqDDuIHIFf918j1L6tACAdRqV0O9zvafMP3RN2Qx7vo-rKtuMBUzcw3Q1cneeVD7Bn9Otou7u77ri6WKYgWx2dBu20DvP5tYbaq2t72lT3chErCq0R3nNTxnzaal2WuNcyeuO6oyOp4A5gJzQyIFljR4odMSEue6NcecRdQV8cNOj29z9NMmYpmPMk3lyqTF36ftcVXlkm4puiVEuW-77UPAHBvK7XmSrVuwE_Bky9viKAmYreH-F1K6f5ciBzPruzFOpFF0ivIG6JJi6PhH3YRiIT1oxFFydtyFRZLrCbpM=s1030-no
Is this an OK card and will it work with the set up below?
Also, my son believes that, worst case, we can build the PC without the graphics card and it will be useable for word processing etc. Just not gaming!! Is this true?!
TIA
17 Jul 2010
That will be a good match and will work just fine.
It won't work without a graphics card though, the Ryzen 3600 has no internal graphics card.
26 Jan 2009
Salisbury, Wilts
2060 is a capable card for 1080p gaming. Should be a good stopgap :)
EDIT
I see OP mentions a 5600XT? The 2060 is as good if not faster. Would be money wasted trying to find a 5600XT as I am pretty sure they are EoL now. The ideal card to look for in the future for a good upgrade over the 2060 at 1080/1440p gaming would be AMD 6800 / Nvidia 3060ti or 3070.
23 Apr 2020
Have you built that PC in the end?
sorry to hear you have troubles with the graphic card, there is a shortage at the moment.
12 Jan 2021
TIA
The 2060 might be very overpriced. Your son is right that you can buy a processor with built in graphics while you wait for a gpu at a suitable price. It can even do basic gaming. https://youtu.be/x78I00NSVTU
