Took the loop out as a whole separate unit and because the tubes are so short I needed the help of my gf to get the pump/res above the radiator and block so the air would leave out of the top of the res, I filled the res up as the coolant lowered and now there's only a tiny bit of air left in there.
I just want a fan controller ( mainly as I've ran out of headers for the pumps plug), some lighting and that'll be it, until I spend a load of money on it again and probably add the gpu with roof mounted rad and a new cpu block ^^
