Advice on water cooling parts.
27 Apr 2009
Hi, im moving my high end Phenom II rig from my antec 900 to a Cooler master HAF X 942.
I was thinking of adding water cooling aswell.
I came up with this:
EK H3O Watercooling Kit - Supreme HF 360, EK-VGA Supreme HF - EN Nickel Plexi, Mayhems X1 UV Blue Premixed Watercooling Fluid 1L and required fittings/tubes.
Will this set up be any good and is it easy to set up?
Better:
YOUR BASKET
1 x Laing 18W DDC-Pump 12V DDC-1T Plus £57.59
1 x EK Supreme HF CPU Waterblock - Nickel Plexi **2011 Compatible** £49.99
1 x XSPC EX360 120mm Radiator - Black £49.99
1 x Lamptron FC5 V2 5.25" Bay Fan Controller - Black £34.99
1 x XSPC Acrylic Tank Reservoir for Laing DDC £22.79
3 x Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin £12.98 (£38.94)
1 x Masterkleer Hose Pack PVC 15,9/11mm (7/16ID) UV-Reactive Black 3.3m £10.88
2 x Mayhems X1 UV Blue Premixed Watercooling Fluid 1L £7.99 (£15.98)
6 x EK PSC Compression Fitting 7/16 [16/12mm] - G1/4 - Black £3.50 (£21.00)
Total : £314.20 (includes shipping : £10.00).
As long as you do your reading and research, you'll be fine. if you make a mistake, we're always on hand to help :)
Much better for long term.
The rads are better, meaning you won't need to upgrade often. The pump is a LOT better. The EK one is borderline really. The DDC I specced is a powerful pump and again, good long term. Silent aswell.
Finally, the fan controller I specced is epic ;)
