- 7 Aug 2003
- Bedfordshire
Hi everyone,
I've been having problems with the electrical system on my ZR7.
The LH indicator wasn't lit but the tell tale and rear LH indicator were flashing really quickly.
After investigating, I identified a lot of rust inside the LH indicator fitting. When cleaning it up failed to resolve the issue, I ordered a new LH indicator assembly which arrived this morning; soldered the connector from the old one and plugged it all in, however, the problem still remains.
Here are the troubleshooting steps I've tried:
1). Wired the LH unit in to the RH loom - same issue.
2). Wired the RH unit in to the LH loom - same issue.
2). Cut the connector off and wired in a 9V battery to the LH indicator assembly it was working fine. Observed that the connector cable was blackened.
With what I've found, is it feasible that there was some sort of short which has smoked the left hand loom? The RH indicators (front and rear) work absolutely perfectly.
It looks like I will have to remove the front headlight unit and the tank to get to some more of the wiring loom, has anyone had experience of these sorts of issues on their motorbikes? I'm concerned that with my bike being 12-13 years old I'll only be able to get a second hand loom, which I might end up having problems with. I haven't found any brand new looms yet :-/
Any help greatly appreciated.
