Advice regarding N80 & N73
Very pleased with my N80, i was going to sell it as Nokia don't do a compatible cradle for my CK7-W hands free kit, but i managed to find a Brodit one, installed it yesterday and it works perfectly.
It's a cracking phone, i don't install all the apps i probably should do apart from satnav (not on this yet though).
Can be a bit fiddly sometimes when sticking it in your pocket and the slider pulls open, but apart from that - cracking!
Mines on "3" btw.
Got an O2 N80 here,
Absolutely faultless for me so far, except for the battery which about 2-2.5 days with normal usage. And its a bit chunky but reasonable i think.
Sid
Thanks for your time.
I really like the look of it, the battery in my 6230i is just terriable, for example I charged up all day yday, went out last night and this morning it was down to its last bar, this is with a new battery as well, very dissapointing!
How does the wifi perform as this is a big selling point for me? Does is easily pick up areas when you are in range?
Range is poor tbh but what can you expect from something this small. The whole phone is smaller than a PCMCIA card
Got an N73, very good phone. Battery is just under full power (since yesterday morning). Camera is superb! Looks much better than the N80 and feels less clunky - but it doesnt have Wifi.
