Advise on connecting hardware to watercooling
8 May 2004
Kent,UK
Hi people
At the moment I have a water-cooling system connected to my CPU / GFX card but I am upgrading my system and had to get new memory DDR2 now I managed to get the OCZ Flex XLC PC29200 really cheap for some reason it was only 7 pound more then other OCZ memory well anyhow I am now wondering how to connect this to my system.
So here is my choices
Some how connect it to my already water-cooled system via adapters because atm it uses 1/2 tubing and the memory only takes 3/8
second make a small loop for the memory only this seems to cost a bit more to me
3rd just go with the aircooloing
D3athReigns
As Jokester says, I'd go with good old air cooling, the hassle of setting up a seperate loop or getting all the adaptors and tubing for you existing one just won't be worth the small drop in temps you'll achieve.
