HA
i notice you are not overclocked, well not in ab anyway. can you use after burner to clock up the core and still have powerplay?
gumpy, try download using explorer, i had the same problem as you with chrome.
yes with the asus 6950 unlocked shaders bios and asus smart doc installed
your using the "EnableUnofficialOverclocking " in AB?You don't need to have smart doc installed now
With 6950 unlocked ASus bios
AB does it all, with OC and powerplay works too
it has the sameAsus bios has much higher overclock limits than the stock bios so you don't need unofficial overclocking.
it wont apply my overclocks on gtx580
it saves the settings but upon reboot its back to stock.
using the awesome 266.35 beta drivers btw.
yeahYou can edit the bios with RBE to up the overclock limit.
840./1325What are the 6950 clock limits on AB as standard without unofficial overclocking or using smart doc ORE?
Surely they have been set higher than 880?
