It's not hard to fit a 120mm front cooling fan in a TJ07Robert said:The thing that worries me about the TJ07 is no front intake.
Elric said:My TJ-09 is fine with Air cooling. I ended up swapping the fans to Noctua's but that's about it, works great, quiet and cool.![]()
Go for the TJ09 you'll love it. Cool and quiet
XysteR said:TJ09 is great for air, and with slight modding to the top for the rad, water. I'm using a freezer 7 pro to great effect in the TJ09, I just got mine and its the best case i've ever seen, + its simply LegendaryGo for the TJ09 you'll love it. Cool and quiet
Massive Attack said:i prefer the TJ07 over the TJ09 TBH
XysteR said:.......TUT! Theres always one who likes to be indifferent
For me with them rolled edges, the TJ07 looks like a £35 something from a computer fair lol You can't beat the simplistic hard lines of the TJ09. Its art man i tell ya!
Richdog said:Air-cooling... TJ09. But if you want to go water and do it properly then buy the TJ07... even with modding the TJ09 simply isn't up to scratch.
I love my TJ09 but starting to regret it a little as I wouldn't mind going water soon and my choice of rads won't be great...
XysteR said:I'll be going to water when i've decided what setup i wanna go with. I've heard that if you look hard enough you can find rads that fit in the TJ09 fine.
Like mineRichdog said:The TJ07 can fit a 120.3 and more in it.
Richdog said:I didn't say that you couldn't find rads that fit... I said the choice is limited and performance undoubtedly suffers as a result
XysteR said:In my experience both in cars and water cooling computers. A radiator is a radiator, nothing spectacular about any of them. So choice shouldn't limit performance
