Connect to its unsecured SSID first then scan again.
It's 3 inches from my macbook and the strongest signal is from the router upstairs, I can't see it from a scan even when I click the wifi icon in the top right?
Why don't you connect via ethernet to set it up?
Have you turned Airport on and off on your Mac?
Plug yourself in via Ethernet and then click the Manual setup at the bottom of the Airport Utility, Click Wireless and post a screenshot so we can see your setup, also you can check the logs by going to Advanced - Logs and Statistics to see what errors are being reported (if any).
Mine was easy![]()
I had the same issue with mine, I had to reset it a few times before I got it working/detected been working fine for the past year though![]()
Have you tried setting to factory settings again? ( thats what I meant by I had to reset mine a few times? )
The only major difference I can see is that you've got the "Allow this network.." check box ticked while I haven't, oh and I've got security configured.
Have you tried fiddling with the channels?
