Akasa AK-183-L2B Amber Ultra Quiet 120mm
Suspended
17 Mar 2006
smsmasters said:
I think I'll get that and adjust the speed via the motherboard headers as I wish. :)
Those fans are incredibly loud, I wouldn't advise running one off your motherboard. It'll damage the mobo. 59dB is incredibly loud, I've had fans in the 45dB range and they're loud enough to hear across the house!
I wonder how many people buy Delta's are only use them for 5 minutes before boxing them up again? :D
HeX
HeX
20 Jun 2004
Huddersfield, UK
TBH the stock fans in the Soprano offer more than enough cooling...
Mrs has that case and has the hot running dual core Presler in there with only the rear case fan running and a CNPS7700Cu on 1900rpm and it never gets over 55C under load...
