Hi,
Quick question.
Purchased the AK-965 Cooler, which came with a thermal pad already applied.
Would you recommend removing this pad and applying the Arctic Silver 5 thermal compound or leaving with the standard pad?
CPU is a 6550. Overclocking to 3ghz gives temps of around 70-75 degrees on Orthos testing.
Bit of a noob with this overclocking so all opinions gratefully received.
Thanks
Quick question.
Thanks
