Akasa Fan controller , 6 Fans ?
if they are low wattage fans you could run 2 or 3 off the same channel on the controler. Would require a tiny bit of wiring, but doable.
Just do as said above. I'm using a vantec nexus fan controller with 3 headers. It's running all the case fans in my case (4 in total). They are all high wattage panaflo fans and it runs fine.
I've done exactly what simonnance suggests with my fan controller and used a splitter like this to connect 2 fans to one of the channels.
So long as you stay within the limits of the power which the controller can supply its perfectly fine. The only drawback is that you can't control the speed of each fan individually.
