First post so be gentle! currently have a few noctua NF-F12 fans but... my case just looks dark.... was looking at the Alpenföhn® Wing Boost 3 RGB fans, cant seem to find a review of them anywhere. Has anyoneh had luck with them? How do they compare to Noctuas fans? thank you
At a guess they won't work quite as well and not sound as nice either. Have you considered using something like Phanteks Halos for £11.99 each? Another option is a RGB light strip kit with power supply and remote control in same price range. Google 'RGB light strip kit' for longest strips. Google 'RGB backlight kit' for shorter (150cm) strip usb powered with inline light control.
Thanks for the reply! The phanteks Halos look pretty good, I dont have any RGB headers on my mobo, Would i need an adapter of some sort? thanks again
https://www.overclockers.co.uk/phan...e-bundle-of-3-buy-2-get-1-free-ca-07c-pt.html Link below is the Phanteks RGB adaptor http://www.phanteks.com/PH-CB_RGB4P.html OcUK also sell a Phanteks adapter cable https://www.overclockers.co.uk/phanteks-rgb-led-adapter-cable-ca-057-pt.html
