Alternative parts
21 Oct 2004
West Yorkshire
Might seem like a stupid question but was wondering if its possible to replace the clutch lever on my suzuki gn125? its not that I can't use it but apart from it being a bit scuffed it also angles out quite a lot and when I bought it, the dealer told me that it is possible to get flat ones or smaller ones that would be easier on my hands.
Not too fussed if I have to just do a like for like replacement, just curious as to what I can do to personalise my wee bike :D
U can buy various different levers for bikes.
My hands are quite small so I had trouble stretching to reach the standard clutch and break levers on my ER-6f. I bought a pair of black stubby Pazzo levers with 5 degrees of adjustment. Been great ever since :)
Had to get the specific ones for the year of the bike though. Since the fixings changed from the 2008 to the 2009.
I looked for you and couldn't find any - just standard alloy replacements.
You could always customise them yourself!
Blowtorch and gentle bending? Dremel to pattern them? You can get lever sleeves if you really want, but they're pretty flimsy.
Also could get a custom streetfighter style headlight?
Thanks guys, I'll have a good read into your suggestions, sure I'll get something sorted. Was wondering whether its possible to replace the whole lever unit or are the clutch cables specific to each model/manufacturer or bike?
Would mean I could just source a second hand/scrap from a bike I like that will fit the cable.
