Caporegime
- 9 Nov 2009
- Planet Earth
The X4 860K is now under £60,and also with the A8 7600 at £60 to £70 having the performance for a £40 to £50 card,its a very good value chip. They will play a lot of quite popular games at reasonable settings(or lowish settings fine) and remember a lot of gamers are not hardware enthusiasts on forums,or even care about max settings or resolution,and if it were the case no consoles would ever be sold then!
I know quite a few people who have done APU based builds for family - so have a few members on here.
I have one of the first APUs,the A6 3670K and its in a relatives PC:
http://forums.overclockers.co.uk/showthread.php?t=18434284
That was a £60 chip and demolished my Core i3 2100 IGP,and its more of the same currently. The A8 7600,for example is probably double the speed at least when it comes to the IGP and its silly cheap now,ie,under £70 now.
Plus I took that A6-3670K rig to a LAN and plonked in my HD5850 1GB I was using at the time to see if it would be an issue,and it was fine. You also need to consider that for these kind of builds you are not going to be upgrading to a £300 card on them and its more likely something £100 or under and you will tend to be more GPU limited.
Plus the FM2+ chipsets have modern features,and the motherboards are cheap. So for their targeted market they do the job.
Edit!!
I would agree it would be fail if desktop Carrizo is 2016,but this is wccftech though and AMD is meant to be releasing their new stuff in 2016,so TBH I would take it with a pinch of salt.
Edit!!
