** ANIDEES AI-7M SERIES - DUAL CHAMBERED GOODNESS, MICRO-ATX STYLE! **
OcUK Staff
26 Nov 2014
Stoke
Brand new from Anidees is the eagerly awaited AI-7M series, the Micro-ATX version of the popular AI-7 ATX Cube chassis released last year. The AI-7M retains the dual chamber approach but has numerous improvements like a horizontally mounted MB configuration, removable ODD/HDD cages, a 200mm front fan for quieter operation and a fan hub/fan controller.
The AI-7M puts the focus on strong cooling performance and maximum configurability, yet retains compact measurements and also keeps the high production quality that Anidées is renowned for. For optimal temperatures, the dual chamber design compartmentalises the interior into two thermally separated zones for mainboard, CPU, GPU as well as drives and PSU.
Stock is landing any day now, get your pre-orders in!
Anidees AI-07MB Micro-ATX Chassis - Black @ £62.99 inc VAT
The dual chamber design divides hot running components, top chamber deliver cooler air to MB, CPU, GPU, bottom one for HDD and PSU.
The chassis comes with a 200mm fan on the front and also can be upgraded with several additional fans if needed. Featuring several options for placing water cooling, providing excellent cooling solutions, the flexibility of this case really gives the users the possibility to create their great system build.
Features
- Direct airflow cooling all compoments
- Support max 8 case fans
-Quiet operation with 200 mm fan (pre-installed)
-Support 3 x 240 and 1 x 140/120 mm water cooling
-3 speed Fan controller (High, Stop, Low), Fan Hub included.
-Spacious but not as big as you think!
-Cube m-ATX Case, Supports m-ATX and mini-ITX
-Supports 1 x 5.25", 4 x 3.5" or 4 x 2.5" devices ( 4 x 2.5" convert from 3.5" cage)
-High end compoments support - Max GPU Length 310mm, CPU Height 180mm, PSU Length 186mm
-Cable routing behind MB tray
-Compact size with 41.5L
-Excellent structural design
-Dust filter on the front, top and side panel
-3.5" HDD tool free
-Full side panel window
-Removable ODD, HDD cage and MB Tray for easy installation
Specifications
- Colour: Black
- Internal Colour: Black
- Dimension (D/W/H): 380 x 288 x 380mm
- Weight: 6.35kg
- Cooling System (Air Cooling): Top: 2 x 140 / 120mm fan (optional), Front: 1 x 200mm (700 RPM, included) or 2 x 140mm or 4 x 120mm fan, Rear: 2 x 140mm fan (900 RPM included)
- ODD, HDD Cage, MB tray: Removable for easy install
- MB Type: M-ATX, Mini-ITX
- Material: 0.7mm SECC Steel, Plastic
- Drive Bays 1 x 5.25", 4 x 3.5" Hidden, 4 x 2.5" ( 4 converted from HDD Tray)
- I/O Panel: 2 x USB3.0, 2 x USB2.0, 1 x Audio, 1 x MIC, Fan Controller (rear)
- Expansion Slots: 5
- Power Supply: ATX PS2, up to 186mm deep (optional)
- Cable Routing below MB Tray: Yes
- Maximum Compability: Graphics Cards Length: 310mm, CPU Cooler height: 180mm
Only £62.99 inc VAT.
ORDER NOW
Anidees AI-07MBB Micro-ATX Chassis - Black Window @ £70.99 inc VAT
Features
-3.5" HDD tool free
Specifications
- Colour: Black
- Weight: 6.35kg
Only £70.99 inc VAT.
ORDER NOW
Anidees AI-07W Micro-ATX Chassis - White @ £66.95 inc VAT
Features
-3.5" HDD tool free
Specifications
- Colour: White
- Weight: 6.35kg
Only £66.95 inc VAT.
ORDER NOW
Anidees AI-07MWW Micro-ATX Chassis - White Window @ £74.99 inc VAT
Features
-3.5" HDD tool free
Specifications
- Colour: Black
- Weight: 6.35kg
Only £74.99 inc VAT.
ORDER NOW
Sounds like an Abit motherboard to me,
Does that make me very old.
And if any of you young whipper snappers say "what's Abit" that will not help. :)
