there isnt a 99-98-97 map. the ecu wont go "hmmm this tastes like half a tank of 99, a quarter tank of 95 and a quarter of 97. lets run the xxx map"
the ecu advances timing for given condtiions, throttle, engine temp, load etc. if detents knock or a misfire etc it will pull the timing for a set time (seconds, it readjusts all the time)
on a WOT run through a gear you can see 2-3* of "correction" at 3-4krpm which then readjusts down to 0.8* by 6krpm
