antec fusion remote owners help
I have a Fusion Mk1, not a remote, but I'm pretty sure the internal dimensions are the same.
I've got a Sapphire 4870 1GB card fitted inside mine, height is fine, just be careful of card length as I had to trim away a bit of the hard-drive enclosure wall to fit the power cables into the end of the card!
Another thing to be careful of is where the power connectors for the graphics card are located, if they are on the side of the card (for example like a GTX 280) and not the end, you may run into case height problems with the power cable connections.
Not currently as I use a Sapphire 4870 which has the connections on the end. I did, however, have to cut a gap through the hard drive enclosure wall to get the lower power plug in due to length restrictions. I may well remove the entire wall and hard drive enclosure moving forwards as all my media now resides on a WHS. This will allow new longer cards such as the ATI 5870 to fit (will have to check height restrictions on this as power plugs are now on the side of the cards!). The OS hard drive can be located behind the display above the DVD ROM using a 5.25 to 3.5" adaptor.
