Antec Kúhler H20 620 Liquid CPU Cooler - IN STOCK
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys, we have received our first decent batch of the H20 620's from Antec (other than the small 10 unit order for launch).
Antec Kúhler H2O 620 CPU Watercooler (Socket Intel LGA 775 / 1155 / 1156 / 1366 / AMD AM2 / AM3 / AM2+ / AM3+) @ £49.99 inc VAT
Finally, there is a liquid cooler for the rest of us. The Antec KÜHLER H2O 620 delivers high-performance liquid cooling for your CPU in a quick, easy-to-install package. Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires no maintenance. The voltage-controlled 120 mm fan, 3rd generation copper coldplate and airflow-enhancing low-profile pump ensure efficient cooling, while the estimated 50,000 hour pump lifetime means this cooler is even likely to outlast the system it cools. Easy-bend flexible tubing allows the KÜHLER H2O 620 to be installed in nearly any orientation regardless of the internal configuration of the case. Finally, the KÜHLER H2O 620 comes with peace of mind in the form of an industry-leading Antec Quality 3 year limited warranty on parts and labour. Take your PC’s Quiet Computing™ to the next level with liquid cooling performance at a price that rivals aftermarket air coolers.
- CPU Socket Compatibility: Intel LGA 775, 1155, 1156, 1366, AMD AM2, AM3, AM2+, AM3+
- Low profile pump ensures exceptional liquid circulation while preserving internal airflow
- Easy-bend tubes for maximum flexibility in radiator positioning
- Intelligent noise / speed control fan for quiet, efficient cooling
- Latest generation copper cold plate for optimal conduction
- Cooling Liquid - Safe, environmentally-friendly, anti-corrosive
- Fan Speed: 1450 - 2000 RPM
- Tubing Length: 330 mm / 13.0"
- Radiator Dimensions: 151mm x 120mm x 27mm
- Fan Dimensions: 120 mm x 25 mm / 4.7" x 1.0"
- AQ3 - Antec Quality 3-year parts and labour warranty
Only £49.99 inc VAT.
ORDER NOW
OcUK done any testing themselves on these? just curious how they perform. in the market for a new cpu cooler and strugging to get one that will clear my ripjaws, if my measurements are right about the only air cooler thats any use to me is the venomous x, tho i would be tempted by the Kuhler H20 if it was producing good results.
If only I had the money :( Could do with something a bit quieter than this stock AMD beasty.
Tell me about it.
I've got a closed-ear headset and can still hear the bloody thing over them when gaming!
I'm looking at an A50 or Gelid Tranquillo - the former being as good as (but a small amount noisier than) the Fenrir, the latter being 1-2'c hotter but much quieter than the Fenrir!
Wouldn't hesitate getting this if I had the money though.
Looks interesting, only issue i have with these things (and it's all of them really) if i switch to one of these, i have to deal with the little fans that clip to the motherboard heatsinks, because asus says they won't get enough cooling if you water cool, so i swap my CPU fan for a quieter watercooling fan, then have to run 2 smaller and hence nosier fans for the chipset coolers and i'm kind of back where i started !
Tempted to ditch my custom loop for one for these as it would mean I could justify to myself going back to air cooled GPU. Then I could get the Gigabyte 480 SOC or whichever one's on offer :)
Tell me about it.
I have it running at 25% when I'm idling and its still stupidly loud. Cannot wait for next pay day.
Will either get a better air cooler or get one of the few CPU watercoolers. Anything must be better than this. :D
Tell me about it.
Akasa Venom - performs on a par with any of those and is silent at its lowest speed (800 rpm) even when it kicks up to full speed it is still quieter than the Fenrir at its lowest speed.;)
