that looks pretty nice, temps seem quite good too.. Is the tubing different to the stuff they used on the corsair units?
Clever man!
The question is tho will it be any better than my megahalems........
so the question is, this or the h50?
"If you're familiar with other Asetek-sourced liquid coolers, you'll notice two things different about the Antec Kühler: first, there are two connectors wired to the pump, and second, the hoses connecting the pump to the radiator are thicker, soft rubber hoses rather than the smaller, stiffer hoses used on other coolers. "
From the link below, posted earlier by Thekwango.
http://benchmarkreviews.com/index.p...sk=view&id=694&Itemid=62&limit=1&limitstart=1
This has a better pump than the H50 so say this (its the pump from the Corsair H70)
Stock Fan Tests
Heat Sink
Thermal Difference
(degrees Celsius) Difference
from Kühler
Coolit ECO A.L.C. 75.2 +9.3
Thermaltake Jing 73.7 +7.8
Corsair H50 73.1 +7.2
Coolit Vantage A.L.C. (extreme) 73.0 +7.1
Corsair H70 (low) 67.7 +1.8
Prolimatech Super Mega 67.2 +1.3
Antec Kühler H2O 620 65.9 +0.0
Corsair H70 (high) 65.3 -0.6
Thermalright Venomous X 63.0 -2.9
Cooler Master V6 GT 61.2 -4.7
I am waiting for the 920I had the 620 on pre-order but missed out so had to wait for forever (or so it seemed) for them to back in stock, in the mean time the date for the 920 was set so I said sod it paid the extra £25 and ordered the it
snip~
I really dont understand why Antec didnt sell this unit with an extra fan and 4 more screws lol, it cant have made it more than £5 more expensive.
Now that thing will be interesting, the radiator is twice the size, and the 620 is already plenty overkill
It looks like the 620 is capable of handling an I7 up to around 1.4v, so the 920 might actually manage to provide decent cooling for up to 1.45-1.5v!
But if people want cheap and awesome cooling, the 620 with two fans installed onto it is unbeatable cooling for its cost.
I really dont understand why Antec didnt sell this unit with an extra fan and 4 more screws lol, it cant have made it more than £5 more expensive. The fan that comes with it is impressive, its silent and pushes a lot more air out of my case than my coolermaster LED fans previously were. Using higher RPM fans on my previous Asus cooler didnt make any difference because the heatsink was already really efficient enough with low RPM fans. With these water coolers, the higher CFM over the radiator, the better they cool .....
Hmmmm, I did find my 60 db Delta fan while I was rummaging around for my spotcools .... Now if only I also had some ear muffs I'd try it out lol.
Temp near 90C is pretty poor indeed. I never get mine over 74C for 4.20GHz with my Noctua D14.
I'm going to order one of these tomorrow. Can anyone suggest a fan to use as the second? And should it be set up in a push/pull configuration?
