Antec P183 or P193 or fractal design D2 help
9 May 2009
Hi all i dont know what to go for i have decided to pick one of these
Antec P183
Antec P193
Fractal design D2
i want a silent case but good build quality, i have herd the fractal door only opens 90 degrees and no reset or hd light would this put you off ?
which would you go for as they all seem to get good reviews
i have used antec case in the past but would llike a silent pc would any of the antecs above be just as silent as teh fractal or is that the better case ?
would like some help
thanks
