Antec Power Supply Deals!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
Here are a few nice PSU deals.
Antec CP 850W Modular Power Supply @ £99.98 inc VAT
Antec introduces the next stage in power supply evolution: the CP Series, an entirely new form factor design made exclusively for Antec’s most cutting-edge cases, such as the Twelve Hundred, P183 and P193. Delivering an excellent price-to-performance ratio, the CP-850’s extended form factor design allows for improved component selection, better circuit board layout, more room between components and a straight-through air path to take full advantage of the large 120mm PWM fan. With 80 PLUS® certification, NVIDIA™ SLI™-Ready certification and Advanced Hybrid Cable Management, the CP-850 is a cost-effective, high-performance solution for your Antec case. And with Universal Input and Active PFC for an improved power factor value, Antec’s CP-850 provides 850 watts of stable power for even the most demanding Antec system. So slide that old power supply to the side; there’s a new form factor in town.
- Larger Form Factor: allowing better airflow and reducing costs.
- NVidia SLI-Ready
- Quiet 120mm cooling fan
- Four 12Volt output rails
- Two 8pin (6+2) PCI-E connectors
- Two 6pin PCI-E connectors
- SATA connectors for Serial ATA drives
NOTE: This PSU only fits into the Antec P183, Antec P193 & Antec 1200 Gaming Cases.
Was £109.99 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
Antec High Current Gamer 750W Quad Rail Power Supply @ £89.99 inc VAT
Making quad rail power and highly advanced power supply design available at a popular wattage, the HCG-750 features special High Current connectors and heavy-duty cabling, earning it NVIDIA® SLI®-Ready and ATI™ CrossFire™ certifications. At the same time the HCG-750 is also 80 PLUS® Bronze certified for efficiency, and features active PFC with a swift, quiet 135 mm double ball bearing fan so you know you're getting not only High Current, but also high efficiency and excellent cooling. If loads of power, High Current engineering and exceptional efficiency are what you're after, the HCG-750 is the perfect PSU for you.
- 750 watts of Continuous Power
- NVIDIA&® SLI®-Ready certified, ATI CrossFire™ certified
- 80 PLUS® Bronze certified - up to 88% efficienct
- Quad High Current +12V rails with high maximum load for better graphics card compatibility
- Quiet 135mm double ball bearing cooling fan with low start voltage
- Four gold-plated 8 (6+2)-pin PCI-E connectors for multiple-graphics card configurations
- All Japanese brand capacitors for reliability
- ATX12V version 2.3 and EPS version 2.91 compliant
- Gold-plated High Current terminals for optimal conductivity
- Universal Input - works on any 100V - 240V grid
- Active PFC with PF: 0.99 - less harmonic pollution, greater efficiency
- Full suite of industrial grade protection:
- Over current protection (OCP)
- Over voltage protection (OVP)
- Short circuit protection (SCP)
- Over power protection (OPP)
- Over temperature protection (OTP)
- MTBF: 100,000 hours
- Meets 2010 EUP requirement: 5Vsb < 1W
- Safety: cUL, TUV, CE, CB, FCC, C-TICK, CCC, BSMI, Gost-R
- AQ5 Antec Quality 5-year limited warranty on parts and labour
Was £98.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Antec High Current Gamer 900W Quad Rail Power Supply @ £99.98 inc VAT
Making quad rail power and highly advanced power supply design available at a popular wattage, the HCG-900 features special High Current connectors and heavy-duty cabling, earning it NVIDIA® SLI®-Ready and ATI™ CrossFire™ certifications. At the same time the HCG-900 is also 80 PLUS® Bronze certified for efficiency, and features active PFC with a swift, quiet 135 mm double ball bearing fan so you know you're getting not only High Current, but also high efficiency and excellent cooling. If loads of power, High Current engineering and exceptional efficiency are what you're after, the HCG-900 is the perfect PSU for you.
- 900 watts of Continuous Power
- AQ5 Antec Quality 5-year limited warranty on parts and labor
Was £116.99 Inc. VAT
ORDER NOW
i have noticed that while you are distracting us with these deals, the 620W version of this PSU has crept up in price.
a shame really, because you would have got another sale from a mate of mine if it had stayed at £50
