Any way to flash firmware on a Dell 2407WFP?
25 Sep 2003
Leeds
Well I went ahead and bought an A03 revision 2407wfp without realising it meant I couldnt use 1:1 pixel mapping. So I cant use it for my 360 on 1080p which is half the reason I wanted it! I read they fixed this with the A04 so I was hoping theres a way to flash the firmware myself, a service port or something. I know a lot of TVs and some monitors have a USB or RS232 service port but I cant find any info on flashing this model. So any possible way to upgrade the firmware to A04 would be VERY useful to me.
Helps?!?
"A04" refers to the "version/revision" not too the firmware (I believe), but you can't turn an "A03" version/revision into an "A04", except by getting an "A04" (or something better) replacement under warranty from Dell...
Maybe others have suggestions...
Yeah I thought that was the case, but it cant hurt to ask eh? From what Ive heard theres not any physical difference though, but that said I suppose it could be a small change in the board layout or something as well as the firmware.
Nope :( Its there but the whole wide mode options greyed out when you run 1080p into it. Any other res is fine, just 1080p. This is on VGA or component. I do have a 360 with an HDMI socket but I havent tried it yet since its banned from Live, that said, I may give it a bash now over HDMI to DVi just to see. Ill report back with results :)
