Any way to read overclockers forums offline?
20 Nov 2004
Stoke
Hi, just sat here waiting for a plane back to blighty and using the free wifi to download reddit offline to pass some time while im in the air and was wondering if there was any sort if app that would enable me to do the same with these lovely forums? I suspect the answer is a big no but i just thought i'd ask.
17 Jun 2012
Should be easy enough to write a quick script if the post numbers are ordered in sequence, just grab the HTML consecutively, but I don't know of an offical app. Google something like, 'Download webpages by number', then take a guess from your URL in your browser what number to start at and finish at.
Man of Honour
17 Nov 2003
Southampton, UK
It'll have to be custom scripts. Smartphones were only just coming onto the scene when the forum software was written, so I doubt it was a design consideration.
30 Apr 2006
London
If it's just for reading, couldn't you just see the pages loaded into the cache?
You would need to have already clinked on the thread for that to work. I think he means a snap-shot of the current forums so he can read offline. As a tube user it would be useful for me as well if the technology exists
7 Nov 2006
Nottingham
The best way is to load the forum on your PC or laptop. Then chose the Sub-forum you want to read, Open a thread, get your smart phone out and take a picture of the first posts, then scroll down a bit and take a picture of the next posts. Rinse and repeat this for every thread and post on the forum. Shouldn't take you too long.
25 Nov 2004
Hertfordshire
Might as well print out the threads and make a book!
EVH
EVH
Don
11 Mar 2004
Wales
:D ... not sure if serious?
9 Jun 2009
OCUK Detention Centre
just rip the whole web site, I just done it with this tool,
http://www.httrack.com/page/2/
18 Oct 2002
If you used middle-out compression you could have gotten that onto a 2GB stick.
Top
