if anyone knows the case then there are only 3 points for fans which is the rear and the top which are filled, however looking up the case spec for other reasons i come to notice for water cooling theres a front option despite no grill or what looks like screw positions and im wonder if this is for a radiator on its own or fan based ones if you can even get away with no fan?
i want to replace my stock cooler, i maybe getting an upgraded cpu for christmas, so i wont do anything till then and have already seen a 120mm AIO cooler i could replace the rear fan with, however if i can stick a 120 or 240mm AIO which are the options for the front then id rather do that and keep my rear fan as all 3 fans are exhausts due to their positions.
