I've moved from a 6850K on X99 to a 7900X on X299 and thus far its been a huge improvement.
X99 is not compatible with 7900X.
Can you expand a little to help with where you have noticed improvements the most?
Games I have seen a noticeable improvement in FPS and in general fluidity, if I use BF1 for a example I have gone from around 100 - 115 FPS on average to being more less pegged at 144FPS. However, I guess some of the smoothness can be attributed to moving to a 165Hz screen. Also game and stream at the same time now without being CPU limited as before it at a notable impact on the games and in some cases it was unplayable. To add to that in 3D benchmarks which I know are not real world examples, the 7900X monsters the 6850K my Timespy benches are a good example of that as well.
In Photoshop, Lightroom, Premier I've seen a subtle but noticeable improved in speed, like applying effects etc...
If you need any more information let me know.
Has anyone done this and realised that their NVMe speeds are shocking?
That isn't hitting the limitation of the PCH yet. I wouldn't bother with 3 x 960s in RAID as you will come across the same issue as I have. Unless you use the PCIe lanes that are associated to the CPU rather than the chipset.Asus/Intel do not seem to want to do anything about it and consider it a limitation of the chipset.
Obviously this is a problem if you have several other components in the system and HAVE to use the M.2 NVME slots.
Anyone wanna share their impressions?
