Anyone got a MDA Vario or similiar?
Permabanned
29 Aug 2005
Reppin' up North London
Hi,
Im looking at upgrading from the Magician (MDA Compact) to the Wizard (MDA Vario) on T-Mobile.
Please answer these Q's for me if you can :) :
1) Is the Remote assistance any good over WIFI?
This function would be really good for me so please post your experiences with it.
2) What ROM should I install on it?
I put the iMate Jam one on my Magician, but what is the best one to use on the Wizard?
Thanks a lot.
Greatly appreciated
MC_Bob
ive got one, had it about a month now.
Not used remote desktop much but it works.
Citrix works fine over it as well.
As for ROM, im using the latest T-mobile rom with AKU2 patch in it and its great, no soft resets for ages.
And push email from mail2web works a treat now.
Robb
Ah thanks mate.
Whats Citrix? I'm guessing an operating system.
I really want to get it and I want to use an O2 sim in it.
I absolutely hate the default T-mobile ROM aswell. So fugly :)
Ill have a search for the other ones.
Thanks
MC_Bob
citrix is just a way of accessing a desktop or applications. We have it for support users. means i can access my servers or email from any where on the planet.
As for default T-mobile theme, you can change it to some thing else. I have SPB today plugin and a few of the other ones, so the front end now looks nothing like T-Mobile.
Robb
http://forum.xda-developers.com/index.php is the best place for info
As for flashing the rom, unless you use T-Mobile one you'll need to unlock the CID else you'll more than likely brick the phone, once you CID unlock you can flash to any rom you like and theres some nice custom ones out there too.
Lokiwiz is the program you need but it doesnt work on newer ones with a G4 flashroms. So be careful.
That just went completely over my head :D
Will have to read up on this :D
Thanks a lot DynaMight and Shoei
MC_Bob
