Takes me 20 minutes just to have the pressure washer ready, buckets out, cleaning mitts, and towels ready. Then another 10 mins to rinse the car before applying the snow foam which take 5-10 minutes depending on the mixture. I then allow the snow foam to do it's work for 30 minutes. But while this is being done i work on the nooks and crannies with either a detailing brush or MF cloth. Once finished I then thoroughly rinse the car this takes 10 minutes.
Alloys are then scrubbed and given a treatment of de-ironiser. The car is then washed with the 2 bucket method, and this takes a minimum of 20-30 minutes making sure no body panel is missed.
The car is then rinse again, and the alloys are wiped down with a MF cloth. The car is then dried after about 5 mins letting most of the water drip off. Which takes around 10 minutes
So we are now at around 140-150 minutes, and I haven't even started on the metal work, interior or even touched the bodywork with polish let alone wax.
I don't consider the above "detailing", what exactly has been detailed?? I'ts not until you begin to work on blemishes, tar removal, claying, and a good polish which is finished off with a high quality wax.
