Mr Men said:unscrew the door handle and take it with you?![]()
Air cooled with Thermalright SI-120/Akasa Amber 120mm (Temps between 39C & 45C on hot days)SiriusB said:Pretty sure you will need some kind of hole - how else will you be able to lock/unlock it?
I think your best option is a tiny webcam [about 30 quid for button sized ones in places] and set up your PC to monitor your room. If someone enters you can show them the evidence - should stop them coming in again
OT: What cooling do you have in your rig? 2.86GHz is impressive for a 4400+
SiriusB
You're right, i completely lost track of where i was and it should be in General Discussion. Oops!t31os said:Off topic - How does this relate to General Hardware if its not about the PC?
t31os said:put it back.
You must be paranoid or really worried about something in your room to be asking though.
Only, my folks actually request the stuff from me to spice up their bedroom manner with their current partners.Booner! said:Pr0n quite obviously! (under the bed!)![]()
Kaiju said:Basically i want to lock my room from the outside to keep my prying family out it while i'm away. Any ideas of such a contraption?
