How about one of these no idea if any good or not. Cannot mention the site as its a competitor but a google will lead the way ?
They're useless. I know. I have one.
Hmm I'll definitely have to look into the burning heater - Does it use a lot of fuel?
i wouldnt have thought blocking the rad would make much difference as the stat should be shut so there should be no water going through the rad.
When it was bitterly cold a few years ago -5c and below, when you stopped driving and were at lights or junctions, the temperature gauge dropped back down to cold, I saw plenty of people with card in front of the radiators that year.
The thermostat isnt an open/closed gate.
Rads are massively oversized for a UK winter anyway. Blocking the rad will help increase underbonnet temps.
Light load after warmup with the heater set high can see coolant temps creep down anyway. Mines far better with my radiator block.
I never knew this, I was under the belief that they were closed until they started to heat up and opened at the rated temp for the engine.
That must mean that cars that have overheated due to a thermostat that was stuck shut has been another fault.
They stop the flow of water to the radiator until the water has reached a pre-determined temperature. Once reached the thermostatic switch opens and the water flows through the radiator and is cooled. If the temp drops below the determined level the thermostat will close and the cycle continues with the aim of maintaining a constant engine temp.
If the thermostat jams or fails to open the engine will overheat. They can also jam open and cause the engine to be over cooled.
