No, it's because it's a WORKSTATION. Spec a Dell workstation up the same and guess what... it's £3,561.
This.
Then when you come to sell the systems after 2 years the DELL will be worth 50p and Mac still well over £1k
he's right you know i have osx on my pc and win 7 on my macbook![]()
I think she got lucky. Not heard of anything like that before.
I know someone in America who got a virus on her MacBook, she took it in...
Store guy: "Erm but Macs dont get viruses"
Her: "Yes they do!"
*Mac employee goes off with MacBook and comes back 10mins later*
Store guy: "Sign this and we'll give you a replacement"
What it was is a disclosure agreement saying she had to agree that she would not tell anyone about her Mac getting a virus, as officially Apple like to pretend Macs dont get viruses. If she didn't do that they would not replace it.
It is limited compared to Windows. Theres simply less you can do on it, less hardware support, and less software/anything available for it. I dont know what else you would call that. And yes i have used it, it's hard not to in my line of work.
Yes. I'm saying OS X is not limited. If you had used OS X for any extended amount of time from a neutral point of view you'd agree. I wouldn't call either OS limited. OS X can do everything Windows 7 does.
But seriously, what's the point in discussing this further because you're clearly close minded and certain you are right.
Prove me wrong, post something you know which makes OS X limited.
If you want to ignore the legal arrangements you can sort of make it work.
But what you have is not really OSX is a hacked version.
Name something you've tried to find for a MAC and couldn't?
Because I highly doubt there's not 1 piece of software for the PC that you can't get an equivalent to on a MAC
Depends on what you're doing whether something being notionally more limited than another product affects you in any way - for instance at home I tend to use Open Office for word processing/spreadsheets but inarguably it's more "limited" than Word or Excel - do I notice the difference most of the time, not at all.
Seriously, why has nobody posted the can of worms pic yet? I don't have it in my photobucket.
It's the same reason Porsche can charge ~£90k for a 911 Turbo but a Nissan GTR is £60k.
It's a premium all round product. You don't like it, don't buy it.
/edit - £107k for a basic Turbo. Yikes
Irrelevant, as the hardware the Apple sells is fully supported.It supports way less hardware, for instance it will not detect or even support as many hardware configurations as Windows does without the need for drivers or modifications.
Source?The OpenGL which it does support is versions out of date.
FalseIt hardware acceleration is limited - No GPU acceleration on OSX in web browsers, pretty big issue this. It's possible to do, but not as easy as Windows has dedicated support and infrastructure in the OS for this.
Dominant marketplace platforms will always have the most software, it simply makes financial sense. It doesn't mean that it's any good, thoughTheres hundreds of thousands more software available for Windows.
For Mac? That's probably because it's not a necessity. There's ClamXAv, iAntivirus and now Sophos that provide free AV.Even yesterday i had trouble finding any decent and free virus and malware protection.
Source?
