aquacomputer w/cooling kit
17 Dec 2005
How do aquacomputer fair in terms of performance. They look good quality, anyone here using them or have any info on their stuff??
cheers
cheers
Nothing wrong with it but its small-bore tubing is less popular on here than larger bore systems as used in the USA and it is quite expensive. Not sure you'll get many comments as not many people here run with it.
I am also thinking of getting the AquaComputer High End Kit.
I have an E6600 @ 3.2 (355*9, stock Vcore), cooled with a Tuniq Tower 120, my temps are:
idle
Asus Probe 26-28c
CoreTemp 40-42c
load
Asus Probe 38-40c
CoreTemp 50-53c
P5W DH Deluxe & Tuniq Tower 120 @ 1650rpm.
Will the AquaComputer water setup better my current temps?? and if so by how much more?
