Any reason to retire your 4 other than bling?
Looking for an excuse to buy one![]()
Yes.....The "5" is costing me nowt!
How is the assembly? Can you describe the steps you went through to install? I'm thinking about retiring my Zalman fan controller and Silent Eagles for some GT's and the Aquaero 5 PRO.
EDIT, whats the difference between the normal and pro version? Is it worth it? Also, can the Aquaero 5 handle 2 loops?
- You'll only need the optional heatsink if your powering a super duper fan setup and water pumps etc. So all I need now is the optional keyboard
Steps to install were simple enough - I've got 3 x Scythe GT (1450 RPM's) connected via a three-pin splitter cable to channel 1 on the AE5. 3 x Corsair 140mm (stock 700D) fans all connected using the same type of three-pin splitter cable to channel 2 on the AE5.
Last but not least I plugged in my Water Pump's 3 PIN connector to channel 4 (PWM monitoring). Oh and power (4 Pin molex) to the back of the AE5. I also connected the USB cable for the AE5 in preperation for the Aquasuite software (to be released this week) - You don't have to connect the USB cable - its only if you want to be able to control it later using the Aquasuite software.
The controls are simple (I thought too simple at first!) - and the options available are just downright immense! - overwhelming at first but once you run through the menu's you'll get the gist of it. Most of it is waaay overkill for just using it as a fan controller lol.
I then set Fan 1 name (To Radiator Fans - now that IS a pain without the keyboard!) and lowered its output down to 1000 RPM. Repeated this step for Fan 2 (name and output) down to 700RPM. -It's actually measured in % but shows what RPM it drops down to so easily configurable. you can also set limits for your fans in terms of actual RPM's so the percentage changes match perfectly.
I ran prime95 for 4-5 hours and noted that even at them RPM's my CPU overclock was still only hitting 57Degrees C (The same as using the GT's at full pelt!) - but the noise reduction was amazing - my PC makes less noise than my NAS box (which has no fans!).
Once I get my water temp probe's adapter I'll be taking it up a notch and be configuring the controller so it can auto adjust from lowest fan settings upto 1000RPM for the GT's (as I know now that I don't need more than that to keep my system cooled under full load). I'm being lazy and rather than going for a in-line temp probe - got one that can be plugged into a 1/4" socket - in effect, i'll be simply connecting this to the fill port on my rad once the adapter arrives (my fill port is slightly bigger 3/8" doh!). When I get round to breaking my loop - I'll add an in-line temp monitor and flow meter (you don't have to use just aquacomputer accessories)
Firstly thanks for the mini review! I do however have some further questions if that's cool?
1)- I have never used a 3 PIN splitter cable. Was there a reason why you used these instead of the daisy chain method?
2)- Ok, so the A5 can regulate the speed of the pump as well? I was on OC forums and there seems to have been signifacant delays with the software although I belive the devs have been working this weekend to try and get it sorted. Lets hope it's not to buggy!
3)- So without the software how do you do it? I assume using the remote?
4)- This is the bit that I am not so clear on. So you have connected the pumps to regulate pump speed and fans to regulate fan speed but not the temperature probs. For me this would be critical as I have two loops and I would want to control them independently. I think what the Asgard is saying is that you would need in-line temp sensors? Would this give me the ability to control my loops separately based on what I was doing?
Once the software is released, updates will come which will allow you to use not only hardware temp sensors but ones built into your mainboard / gfx's to control outputs too
stock availability would probably be an issue at the moment. i have tried to get one for myself recently and they are like hens teeth.
i will have a chat with Nath on monday for you guys and see if we have plans to get them in.
we are currently in talks with suppliers and manufacturers about this.
as i mentioned last week, availability is the issue here and really the only thing holding us back.
i will keep you all informed about any updates but the ball is definately rolling![]()
can't get the AS 2012 to install at all
Runs through the pre-requisite install (dot.net 4 etc.) but when the actual AS 2012 install starts, I just get a blank, white window and the install does nowt.
Andy idea's zoomee?
win 7 64
tries reinstall .net 4
ran in XP mode
Ran as admin
Still no joy
Aquaero is XT
Only thing you won't be able to do without the software is sync date and time with your PC, and juggle the screens around (well easily anyway!).
