Aquaero 5 Series
  • Thread starter Thread starter rjk
  • Start date Start date
Hmm.. Just got my aquaero xt... How do I connect my pump to control voltage to it?!! Does it just go through a molex to fan plug converter in a fan channel? Or do I need some kind of powerbooster doo-dah?
hello lads,
im thinking about getting meself one of these (prolly pro version) one question though:
i want to use it purely for an air cooled system and want to include control of the cpu fan as that's by far the noisiest element. will the automatic control go by the mobo temp sensing or will i have to use a different sensor? and if its a different one how would i do this to ensure i'm not going to overheat it? i've heard of people putting a very thin sensor between the cpu and cooler but wouldn't thing impair the coolers ability to transfer the heat?
i think that was actually 3 questions soz :rolleyes:
but any help would be most helpful before i go spending over a ton on something that won't do what i want.
cheers
jim
bugger bought now :(
ahh well so long as they get it sorted soonish, at least i can control all the others and set the cpu cooler at a manageable setting.
cheers for the post though, from what i've seen they seem to be working hard at improving the software.
laters
jim
