Arctic Cooling Freezer 7 Pro Rev 2 not working
28 Apr 2010
Have you got any fan management enabled in the Bios, if so go disable it or recalibrate it with your new fan.
Dave.
23 Aug 2010
ive just built the computer if that makes any difference
just tried it with the stock cooler and it works... i think the freezer pro is broke...
Man of Honour
13 Oct 2006
If its still very cool the fan won't spin (happened with my ACF7 pro) - unless BIOS is set to duty cycle. Try doing something to make the CPU work and see if it spins up - but monitor carefully incase it really is broke don't wanna have the CPU overheat.
20 Feb 2009
my old rev 1 would kick in when the temp got high enough. not sure if thats something that was set in the bios
Top
