Arctic Freezer 7 fan speed not detected
2 Jan 2009
I've just installed an Arctic Freezer 7 CPU cooler in my PC to have a play with overclocking before I buy a new rig.
When I first booted up I got an error beep from my motherboard saying that the CPU Fan speed is too low.
In the Bios there is an option to give a warning when the speed drops below a certain speed (e.g. 1200 rpm), I also noticed that the speed was being shown as Zero but I had the side of the case off and it was spinning fine.
Just downloaded Speedfan to have a look and that shows 0 rpm as well.
Any ideas??? Temps are better than the previous cooler so it's working but I'd like to have an idea on the fan speed.
Running an AMD Athlon 64 X2 4400+ on an ASUS A8N-Deluxe motherboard.
Thanks
Have you enabled the cpu q fan function in bios, can be found under the hardware monitoring section in bios. Youll need this enabled along with one of the fan profiles, eg silent, standard etc.
I've just tried out the Q-Fan option, it enables a CPU Target Temperature to be set but there is still no info on the Speed.
Looking a bit more carefully inside the case there is a 4-pin connector from the Freezer 7 but only 3 pins to plug into on the motherboard for the CPU fan.
I'm guessing that the 4th pin that is not being used sends the data on the speed??
Hi eddie86,
Your using a 4-pin PWM Fan plugged into an older motherboard featuring a 3-pin fan header. This should still work and you should see the fan RPMs still as afaik the rpm reading comes from the 3rd pin which you are using . . .
Pin 1 Gnd black
Pin 2 12V yellow
Pin 3 (tach) sense green
Pin 4 (PWM) control blue
The only disadvantage you should have is a fan that is always running 100% . . .
Are you sure you got the fan plugged into the correct fan header (CPU not CHASSIS etc)? . . . assuming you have it plugged in correctly and to the right port then either the fan cable is bOrked or the fan-header is? :confused:
It pains me to say it as it is rather embarrassing but you are absolutely right.
I plugged it into a Chassis Fan header...:rolleyes:
Serves me right for fitting it in poor lighting conditions :o
I don't suppose you have any experience in overclocking AMD dual cores like mine do you? I've got a couple of q's....
was just about to say this lol. oh well u fixed it now, just hope yours wasn't as crap as my dads! That thing went straight in the bin, piece of crap
Great!
I'm having a bit more of a play now I have a better cooler.
Stock settings were:
CPU - 2200 MHz
vcore - 1.35 V
Ram - 200 MHz (so 400 MHz as DDR)
I'm now PRIMING as I type at:
CPU - 2552.3 MHz (x11 multi with 232 bus speed)
vcore - 1.475 V
Ram - 182.3 MHz
So the questions,
1. Safe maximum temperature and vcore? - there is loads of rubbish on the internet and I don't seem to be able to find a decent answer so far.
2. The vcore does not match (exactly) what I specified in the BIOS and it does not stay stable as reported by CPU-Z, it varies from 1.488 to 1.504 V and even more at the next highest increment. Is this ok?
3. What to do with the Ram speed when the 'dividers' are so wildly far apart, for my current settings it is either 182.3 or 232 MHz, so which to aim for?
4. What is the max speed I should aim for?!
Heh I agree with the load of rubbish bit! :p
I would say you don't have to worry about the safety bit or maximum vCore as the thing that will hold you back is the temps . . . . once you reach a certain speed using mortal cooling you will hit a brick wall due to the temps, can't say for certain if this is a CPU/IMC situation or perhaps something to do with the MOSFETS but the Athlon X2's really don't clock well past *roughly* 65°C
Well that's perfectly normal although as an overclocker I can't say any of it is desirable! ;)
The difference between what you set it BIOS and the resulting vCore as displayed under CPU-z is refered to as vDrop. Basically ignore what you set in BIOS and use the reading in CPU-z as your target. If you have to set 1.60vCore in BIOS to attain 1.45vCore under CPU-z then consider the chip as being fed by 1.45vCore and forget the 1.60VCore reference other than thats what you need to set in order to attain 1.45v!
Once you take the chip from Idle and Load it up with a diagnostic you may see the voltage displayed drop lower,again this is normal on older system as is refered too as vDroop.
Ideally an overclocker would want to set a certain value in BIOS and have that value applied to the hardware but it doesn't wuite work like this, at least on all the hardware I have used myself the past 15 years! . . . you can get around vDrop by using CPU-z as your vCore readout, you can kinda get around vDroop by bumping the voltage high enough so that at its lowest Droop there is still enough juice to keep the loaded processor stable.
On more modern systems there is a feature called Loadline Callibration which does a great job at negating vDroop. Another thing that *may* be worth looking into is the cooling on the motherboards PWM's, these take the course power from the PSU and convert it into finer CPU ready power, if the PWM's start overheating beyond a certain point I think they struggle a bit at delivering the clean ripple free power i.e if you have well cooled PWM's the vCore line should hold fairly steady once the chip is under load.
The only other thing to mention is always make the distinction between the vCore you set in BIOS and the vCore reading you see in CPU-z when communicating with others through the Interweb, vCore-BIOS, vCore-Actual etc as I think this will be more useful to others! :)
The fastest possible setting that also is fairly hassle free, YMMV but if in doubt try them both out yourself and see if you can notice the difference, if you can't notice the difference in the real world then you can always use some benchmarking software to see if anything is happening! :p
Of course give the RAM full respects and make sure it is well cooled and running with reasonable voltage as baking hot/over-volted sticks tend to die! :eek:
Well that depends, one normally tries to find the max possible fully stable MHz, some others don't really care for stability and will aim for the max MHz that can complete a benchmark or in extreme cases stable enough to validate CPU-z before the machine BSODS . . . .personally I am only interested in fully stable overclocking so I will spend a fair bit of time trying to get the speed as high as possible while at the same time being able to complete lengthly Prime95 testing and long gaming sessions.
In your case with the Athlon 64 X2 4400 I would be aiming for about 2.5GHz-2.6GHz although if you have a rare chip and great cooling you could get up to 2.8GHz running stable! . . . . having said that once you get all your testing and benching out the way you may decide on a slightly less ambitious speed for day to day useage . . . the higher the voltage you chip needs to reach higher speeds means the higher its energy usage, this may not be a real problem if your machine is running a few hours each week but if its 24/7 then you can't ignore the increase running costs £££ pumping the vCore brings . . .so with that in mind you have to work out what is your personal sweetspot!
Hope some of this has been helpful and buy yourself a headtorch for the next time you have to build in the dark! ;):cool:
Thanks for the advice Big.Wayne and taking the time to write it too, much appreciated.
I've got a few more questions now lol.
The vdrop and vdroop that you mentioned appears to hold true until I go up to a BIOS vcore of 1.475.
At this value the vcore-Actual is shown as 1.488 to 1.504 V and jumps between the two whilst running PRIME.
Is there any reason why it is being reported as higher than the BIOS vcore?
Second question, is there a setting/speed of something in the BIOS that I have forgotten to change? My current settings (stable after 30mins of PRIME and counting) are below:
CPU - 2574 MHz
multi - x11
Bus Speed - 234 MHz
Ram Speed - 333 MHz (equates to multiplier of CPU/14 so 184 MHz actual)
HTT - x4 multiplier (936 MHz)
PCI - locked to 33.33 MHz
PCI-e - locked to 100 MHz
Temps were 51ºC for core #0 and 60ºC for core #1
How come one core is so much hotter than the other? This was the case with the old cooler as well.
Last question now I have thought of it, when I set the bus speed to 237 MHz it actually came out at 237.8 MHz. All the other increments were spot on in CPU-Z, any reason why?
Thanks again!
Ed
(strictly daytime only PC builder)
